1. Is RTV or a sealer only used reinstalling the lower-unit vs the water-pumps housing if no gasket is used (when replacing the impeller on a 1970 35HP Chrysler)?
2. One set on instructions mentioned coating the water-pump?s housing screws with RTV (I feel due to corrosion but I?m in fresh water but will coat them). I have not seen any instructions on using a sealer to install the housing w/o a gasket. Please see all parts in attachment.
3. I feel I?m seeing a slight sign of a sealer on the housing and plate but not an RTV type or gasket.
4. It?s time to put the Monster back together vs letting time slip upon me.
Thanks for your advice in advance.
JOW
JOW
