Is switching to Aftermarket reeds worth it?
dfrants
I have a 1988 Mercury 200hp carb V6, she idles a little rough and I currently have her on a Hydrostream ski boat. It was suggested to me to try high performance reeds, that the back in the day all these Merc guys were putting in Boyesen reeds for better performance... anyone here have any experience with them? what kind of performance gains could I see???
cyclops222
Is there a set of idle speed mixture and idle speed screws to adjust better ? Are the sparkplugs the correct ones ? Do they look not perfect ?
Chris1956
Some of those earlier V6 motors had fixed idle jets. The carbs must be spotless and the floats exactly set right to work properly.
Dukedog
tha only thing you can do ta idle is tha timin'... all wh (used on all merc V6's from '76 ta '90) series carbs have an idle circuit that is not adjustable.. its either jack with timin" or change idle "air" jetting..
reeds are justa choice.. most change 'em looking for performance gains which really won't happen with a stock production motor.. they do, most of tha time, affect tha idle if tha metal (production) reeds are gettin' old......... jmo
Dukedog
these are a coupla more choices.. we like these better than boyesen..
Faztbullet
IMO Boyesen are junk and will last about 2 yrs tops. Will last 30 seconds if it ever sneezes. I only use the above, mostly Chris's reeds. If motor is new to you the intake may be crossed drilled which will effect idle a tad.
