is there a 44" version of the gray pump hose (old style)?
CamaroMan
All i seem to find is the 29" versions to the lockout valve, but i would like both hoses the same length - inline 6 with the trim pump mounted on the stbd side of the block..
For the black I have 32-59841 but not 100% sure what part number for the gray hose. fwiw this is the smaller (old) style that takes a 3/8 wrench, i presume this is a 3/16 line? And the newer line is 1/4" (7/16 wrench)?
Ayuh,...... Whatcha workin' on,..??
I'm guessin' an ole MC-1 if it's got a lock-out valve,.....
CamaroMan
hi - this is an older i6, but no lockout - has a newer style pump with adapters to convert from the early style at the pump, however all the diagrams i found go via the rev lockout- could not find a matching gray hose in the same length as the black. I did find a set of lines at the shop that are same length black/gray and the earlier style i just could not get a part number though..
