I have a 1999 Glastron with 305 GM engine and raw water pump. I have looked at numerous pictures on the correct position of the impeller splines for the raw water pump and they are different. Is there a special way the impeller HAS to go in or will the splines fall into correct position as the pump rotates?
Is there a front or a back to the impeller - looks the same to me. And, where does the plastic tab that comes with the kit go..in the back or in the front of the pump? Thanks for the assist since I'm now questioning my install.
