Is there a Fuel Pump Repair Kit? 84 Evinrude 115hp
Hartzhoop
Got an '84 Evinrude 115hp with the VRO pump. I mix the oil/gas manually since the oil side stopped working long ago. The engine has run excellent till this season. Will idle but not run past an idle normally, unless you pump the key primer or the primer bulb. I've checked the primer bulb, fuel tank intake, and vent...Is there a fuel pump repair kit for the '84 115hp Evinrude? Where would you find it?
