rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Experimenting with props. Spec's below. Original prop runs good. WOT is in range, hole shot good. Speed not bad. I'm looking for a bit more speed so I can back off the throttle for cruising speed(is this possible?). Currently I'm "crusing" at about 5k rpm which seems high. Curious If I can maintain a decent crusing/plane speed and reduce some of the RPM's for better economy If this makes sense?
Ok, I have:
19'6" Sunbird neptune 202 Walk-Around Cuddy cabin appx 2000lbs
1993 115 Johnson (1993) 2-stroke 310lbs
WOT with current setup is 5400 rpm
Hole shot good
Speed "not bad". I dont measure speed overall, just RPM
PROP= 13 3/4" x 15Pitch Michigan Alum.
I typically carry about 20-30 Galls.
The only other I tried was a OMC S.S 13 x19". Man, It ran like a dog on the boat. Thought something was wrong. No Hole-shot, no speed and could only maintain WOT of 4200 top.
I have spares of 13 1/4 x 17" and a 13.375 x 17". Do you guys think the 17 Will be benefitial for what I'm looking for. No Skiiers, just fishing and cruising to fishing spots.
Appreciate the input.
MR
Ok, I have:
Hole shot good
MR
