is there a way to test a mechenical fuel pump? not getting fuel to the carburetor
undecided69
i replaced the fuel filter last year when i winterized the boat. I checked for clogged fuel lines n clean out the fuel tank i took of the fuel pump remove the fuel out line n push on the fuel pump rod n i got a couple of squirts of fuel out im no mechanic but i don't think it was sufficient fuel to start the engine. Before purchase a new pump i was wondering if there was any tricks to test these pumps the engine is 120hp omc 1977
Boomyal
Re: is there a way to test a mechenical fuel pump? not getting fuel to the carburetor
You can get an inline fuel pressure gauge from any autoparts store OR you can just disconnect the fuel line at the carb and crank over the engine. Careful that you do not allow the gas to splash on everything. Mechanical fuel pumps usually develop between 3 and 7 lbs.
Ayuh,.... The motor regularly does that several Thousand Times a Minute,....
Like Boomer says, yer lookin' for 4 to 6 psi, 'n good flow,...
A redneck flow test is divertin' the output line into a jug,..
It'll fill a pint jar fairly Quick...
undecided69
is the only way to prime the pump to keep turning the key.
Ayuh,... Splash abit of gas down the carb's throat,...
Usually only takes once or twice,...
Boomyal
I have a glass syringe (w/o needle) in the glove box. It is great for squirting a bit of gas down the shoot.
undecided69
thanks ill try to fired her up tomorrow I hope it works.
