I have a 93 120 Force. I have replaced the thermostat that is housed above the cylinders. (The spring loaded one, 130 degrees) I have read posts that there is another one somewhere that should be located off of the hottest cylinder. Is there one? <br />I have looked verywhere for another, but am unable to locate it. I am assuming there needs to be one somewhere because something has to send the signal to the alarm. The one above the cylinders does not send any signal, correct? I am assuming since there is not wires or anything coming from the 130 degree one.<br />Thanks for any help.
