Re: Is there supposed to be oil in the lower unit?
You have a leaking seal somewhere. You need to drain all the oil from the drive and pressure test it. Once you find the seal that's leaking, replace it. (That's the fun bit
Look in the stickies and you'll find a lot of information on building a pressure tester (very easy), and the test procedure.
Chris.....
