Glastron175
- Joined
- Mar 13, 2010
- 71
Engine info: 3.0GS MEFS, 3869051, SN 4012036649
The problem is that it runs fine at any speed, but anytime I mash the throttle, it stalls and even dies unless I quickly back off the throttle. I can accelerate slowly with no problems. I suspected the accelerator pump and put in a new Holley kit (it is a 2 barrel Holley carb) and did not solve anything. I disconnected the throttle link so that I could manually advance the throttle and when I do it squirts two streams of gas as it should.
Could the problem be timing, or advance timing not working properly? I don't have an inductive pickup on my timing light so haven't been able to check it yet. Also, could the power valve be the wrong size. My vacuum measures 15 inches at idle, and I have a 3.5 power valve. Any ideas or comments appreciated.
