Re: Is This a "cupped" prop?
That prop looks to be slightly cupped. Cupping is a curvature added to the trailing edge of the propeller. It is usually very slight, about 1/2 to 3/4 of an inch from the trailing edge down toward the middle of the blade and shaped like the bottom of a bowl. It is used to reduce cavitation and in some cases maximize thrust. Cupping basically makes an inefficient propeller run more efficient. It also affects pitch by effectively increasing it and will reduce RPM.
On the picture you refer to you can see the reflection on the trailing edge that appears to show cupping.
