Is this a good marine cam it came in my 454
crazygn
I trashed my 350 last year and just picked up a 454 to swap. What's needed to do this, will the mount need to move or bolt up and what about the flywheel is it the same one on my 350. The 454 I have cam with this cam will it work for a marine cam.
The cam is by a custom cam grinder
Camcraft cams in N/carolina
#51-2530-10A4-HCR
Advertised duration 276/288
.050 226/230
Cam lift 314/320
Valve lift 534/544
Zero valve lash
Centerline 106/114
Lobe seperation 110
Valve timing At .050
In.open 7BTDC In. close 39 ABDC
Ex. open 48 BBDC In. Close 2 ATDC
Re: Is this a good marine cam it came in my 454
Nope,.... but I believe the motor mounts are the same...
picklenjim
If you plan to run stock exhaust with that cam there will be a good possibility of water reversion with only 110 LS. Stock exhaust prefere 114+ lobe seperation.
crazygn
I'll run stock type manifolds with after market risers
NHGuy
Hey crazy, Picklenjim is definitely a motor guy. He ain't just blowing smoke, but if you ignore him your new motor could be.
Get a marine stick and get the benefits of the 454.
Reversion is what happens when there's enough valve overlap to suck some of the cooling water back up the exhaust, when that happens stuff breaks.
If you just have to run the hi po cam you will want to figure out how to do dry (loud) exhaust. Then you run into noise rules.
I still say get a marine cam.
crazygn
No Iam not going to ignore him haha I had this problem before. I can post the whole cam card if it will help . If you really think it won't work then I'll start looking at cams
achris
More fish than mountain goat
One question.... Is this an inboard application or with a stern drive unit? If it's a stern drive, which drive, Alpha or Bravo? Ok, that's 2 questions.... My bad.....
Ayuh,... For how long are the risers Dry, before they dump their water..?? relative to the stock risers....
crazygn
The boat is a 1989 Larson senza 210, it will have about 320 hp 454 engine. Outdrive is a 1.5 alpha drive with a 21 pr 23 prop. The risers going to be welded about 16" longer then what stock is to see if that helps
picklenjim
Thats a lot of cam for only expecting 320hp. That cam is more for an engine in the 400+hp range. You could build a 350 that will make 320hp pretty easy. You will need all the other parts to compliment that cam or it's gonna be a pig. What heads,intake and carb do you have?
Next problem is your going to over power that alpha drive. I believe their only rated for 300hp max.
crazygn
I will get the numbers off the heads after work I was told theRe junk heads. It's a 80's 454 and I know it has a stealth intake. Ian gonna try to take it easy on the drive tell I get a deal on a bravo drive. I have 2 carbs belive one is a 600 and the other is a 750
