skysurfer2010
- Joined
- May 26, 2009
- 159
I need a new prop since the last ride of my season last year I must have hit something in the water and I took a chip the size of a quarter out of an edge of my aluminum stock prop.
I went to this website (http://www.dansdiscountprops.com) and it had a "prop wizard" that selected some props based on the information entered:
My Boat
97 Monterey Montura 18.5' br 86" beam
2,200lbs dry weight
Volvo Penta 3.0GS 135hp SX outdrive
WOT should be between 4,200 and 4,600 according to manual
14x19 omc original prop
4,900rpms indicated on stock tach WOT
34mph top speed indicated on speedometer when it decides to work
Typical Riding Conditions
often 2 people, sometimes 4, rarely 6 (none over weight
average 16 gallons of gas
sea level
calm to light chop fresh water
*No watersports yet, but I'd like to get into them this year. Boat will still be used primarily for cruising with the occasional skier/tuber.
Based on this information, the prop wizard recommended these props:
Hustler aluminum 14-1/4 x 19 (for watersports) $111 with hub kit
Hustler aluminum 14-1/4 x 21 (for speed) $111 with hub kit
Since my boat was indicating a higher rpm at WOT than what's recommend for my engine and the stock prop is a 14x19 I'm thinking the 14-1/4 x 21 might be a better choice? Is this correct? Ideally I'd like to pick up some top end speed. Also, is Hustler an ok brand?
Also, I was looking for a step by step with pictures on how to do a prop swap but wasn't able to find anything. I also looked on you tube with no luck. It looks relatively easy, but I can't visualize the part of putting a block of wood behind the prop to remove something. Does anyone know of a step by step with pics/ video on how to do this? Also, how difficult are these to remove? I wouldn't be shocked if this is the original prop it sold with 13 years ago.
Thanks for any replies/ advice in advance.
My Boat
2,200lbs dry weight
sea level
