jgresham75
- Joined
- Aug 19, 2008
- 70
Installed new Holley carb (marine 2300) on my 5.7 GS and trying to get all the adjustments correct. Once installed, it would bog down under hard accelerating but would do fine with a slow increase. Replaced the new accel pump nozzle with nozzle from old carb and bog almost disappeared. However, I still have a small bog, enough to annoy the skiers trying to get up. Pretty sure not the power valve as I used the 4.5 as per the Volvo manual and this forum. Also have the 50cc pump and adjusted it per the manual and this forum.
Therefore, it seems I might need a small adjustment up or down on the nozzle size. My questions is how do I determine if the bog is caused by a lean or rich situation in the nozzle flow?
