Re: Is this a sign of bad gas?
Thats the inner lining of the gray fuel line.Cut a piece of your hose open.
+1. I just finished going through that exact fiasco with my boat.....grey OEM fuel line, 12 years old. In thinking it was a problem in my popular (mfgr) plastic fuel tank, I thoroughly inspected it and found nothing but clear fuel. It was not the problem.
One thing that helped identify the pieces I had, exactly the same color and all as yours, was that most had a curvature to them that would fit a 5/16" circle if joined, which is the dia. of my fuel line. The "stuff" was in my squeeze bulb, all my engine fuel lines up to the filter, in the filter and in the water pump. I replaced all that and in replacing the tank to bulb line, I used a clear PVC tubing for a time so that I could inspect the fuel coming in to ensure that I had the problem.
I did and after the proof, I replaced the line with fuel line from my local auto parts store.
One of the mechanics on here did mention to me in an answer to my posting that that line should be replaced periodically to prevent that.
HTH,
Mark
