Is this boat a good deal?
seasalt35
I paid 850.00 for a 1977 bayliner skagit with trailer good mercruiser setup good out drive good hull bad motor, I heard bayliners are not a boaters favorite but thought the price was :rolleyes:reasonable
Barnacle_Bill
Re: Is this boat a good deal?
Personally I think that was too much for a 31 year old boat with a bad motor. But bottom line is if you are happy with it and have the money to fix it, then have at it and have fun with it when you are done. Just my opinion.
erlindbl
If everything is in good shape but the motor, and you know what your doing and can fix it cheap, then what the heck - - sounds like a deal....... If, on the other hand, everything else is not in good shape, that $850.00 is just the begenning. I'm hoping it's the former but experience tells me it's probably the latter.
Good luck
roscoe
Not a bad price for a 22'er, hopefully the repower is all you need.
Happy boating.
reelfishin
If indeed all it does need is a motor, and your capable of doing the work yourself, it can be a fair deal. If you have to pay a marina or if the rest of the boat needs work, it may have been more worth your money to invest in a better boat even if it needed the same work.
Most of the Bayliners I see end up at the dump, most were bought by first time owners and never got proper care and storage. Everyone I've run across so far has been a soggy, wet mess needing new floors, transom, and flotation foam, besides any obvious mechanical problems.
Myself, if I'm going to go through all that work to fix up a boat, I'd rather put my time and money into one that is better built from the start, and one that will maybe be worth a bit more if I decide to sell it.
On the bright side, even if the boat turns out to be not worth the trouble, if it's on a decent roller trailer it may well have been worth what you paid. You could also part out the rest of the boat to recoup some or all of your investment and find a nicer project.
I'd start off by looking real close at the deck and transom and maybe even weight it and compare it to the advertised weight, if it's way heavier, it's full of water logged foam and rotted wood.
Uraijit
Banned
Like others have said, you probably want to carefully check that the hull is sound, before putting money into the engine.
But, even if it's not. You can easily make money on the deal by parting it out.
What drive/engine combo do you have?
turborich
What size engine? If it's a 305 or a 350 V8 it should be pretty easy to find one. I have also seen the 4 & 6 cylinder mercruiser engines for sale at reasonable prices on craigslist.
If you like the boat then that's all that matters! I just picked up my 1st boat, It has a good engine but needed a drive, I located one for almost free! If you search around you will find some great deals!
Got any pics of her?
