Re: Is this boat sea worthy...
Beefer, I am serious and I don't care what you grew up on, you give your opinion, I gave mine, I will not change it to suit what you grew up on.
I/O have a huge bilge, need bilge pumps, rarely have self bailing, sealed decks. The engine is below the water line and the bellows is as well. If the bellows tears then down you go, blub, blub, blub.
If you want an inboard, get an inboard, not an I/O. The larger the boat, especially once they are above trailer-able size, inboard boats make huge sense. No, most are not self bailing but once you are that big, you also have huge freeboard, large pumps etc. Size matters.
Can an outboard drown, sure, if the boat is upside down or it is a design that cannot keep the power head above water when the decks are awash, that is why I included the photo. The bottom boat is likely to flood the engine out and roll over, the upper boat is much less likely to do so. Any small boat can capsize and none are self righting once upside down. Thus my statement that small boats and seaworthy in the same sentence is difficult.
Good luck
You're entitled to your opinion, and I don't have a problem with an opinion, it's misinformation that I have issues with.
You say that: "I/O have a huge bilge, need bilge pumps, rarely have self bailing, sealed decks."
My 22' I/O has a smaller bilge area then my 16' OB did, and smaller than many OB bilges
So OB boats don't need bilge pumps? Good luck with that
My 22' is self-bailing, and most other-than-beach-barge boats (ie. fishing/offshore) are self-bailing
Once again, I'm running a sealed deck
Please watch this video:
http://www.youtube.com/watch?v=c48IWQ7vWEE
According to your opinion, this boat should have never sank; OB, self-bailing, bilge pumps, and over 24'. Sad thing is, the motors wouldn't start, even though the boat was right-side-up, hadn't rolled over (yet), and the powerheads were above water. They wouldn't start because water was getting into the huge bilge area (see integrated swim platform), and shorted everything out.
And FYI, I would say that 90% of inboards ARE self bailing, and tend to have
lower freeboards (see Bertram). And, all that's keeping water out of the boat is shaft packing.
Funny thing is here in FL, there are tons of boats. Every year I see numerous news articles on boats sinking. I see very few I/O's sinking, and the majority of the boats that do are OB's. Yes, I/O's have bellows that can fail, but regular maintenance and upkeep can prevent those failures. I'm sure there are more thru-hull fitting failure sinkings (on all types of engine designs) then there are bellows related sinkings.
