anthonysjo
- Joined
- Mar 10, 2009
- 51
Attached are some pictures from what I believe is a 1995 Cobra drive on a 1995 5.8L. I understand that OMC is no longer in business and parts can be a little difficult to find. Should I cut loose of this boat and look for something else or is it just a little more difficult to find parts. I would also like to know if the outdrive is the same as the Volvo and if parts are swappable. I am also looking for the screws to drain the outdrive and I am not seeing them even though I have seen pictures on where they should be so maybe someone can tell me the exact drive I have based off the numbers I provided in the original post. Last question is on the drive filling procedures. I have drained out of the bottom and based on what I have read is that you must fill from the middle hole and check at the top dipstick. What I am not sure of is if I have the center fill hole as it does not appear so and if I do I want to verify the location as I don't want to remove a screw that should not be removed. With both sets of screws not appearing as I have read the should I am questioning the exact drive that is on the boat.
Thanks for the help!
View attachment 173142View attachment 173143View attachment 173144View attachment 173145View attachment 173146
