imraan47
- Joined
- Sep 18, 2009
- 315
Hey guys.
Ok so i just had to get pictures so that i can get better response's to see how this can be fixed.
the first 6 pictures..you can see tons of crazing and in this area which is all pretty much at the sides of the boat and some on the transom. You can see the cracks and also some of the paint or is it gel coat that has come off and its exposing whatever is under there that is black in color.
What can i do about this situation?
Also next 2 pictures picture you can see the brown marks and that i guess from the boat being in the water. i don't understand though why its that low since the water line should be much higher but anyhow how can i get rid of that? on previous threads i was told to do a acid wash by using some good janitorial type of stuff. is there anything else that perhaps can get rid of this marking. i doubt that a simple cleaner will get it all out so that i can make it shine again.
since there are a lot of cracks (crazing) and those area's where it looks like holes, i was thinking of fixing that and I'm sure i need to paint so if i did that then the brown marks are taken care of..so in this case whats the right paint to be used on this.
Thanks to all in advance and to iboats.
