Is this low compression 3 hp Johnson JW 10
fishon71
I have an old 1953 Johnson JW 10 three hp that will not start - has good spark and super clean carb. The compression is 75 psi in each cylinder, is that too low? Has a tiny bit of life after 20 pulls some times, my arm is getting sore. I thought anything above 50 psi would run.
oldcatamount
Re: Is this low compression 3 hp Johnson JW 10
that's not to low, it should run with those numbers. You have other issues there. Mybe try not using the choke quite so much when cold starting. It's possible you are flooding the motor. Also be sure to have fresh fuel.
fishon71
Thanks - What is a good starting point for the carb adjustments, I have them each one turn out now
oldcatamount
Try 1 1/2 turns on the low speed needle. I think the high speed needle is one turn but not sure.
lindy46
Have you cleaned/replaced the gas filter on the on-off valve coming out of the gas tank?
fishon71
Yes, and there is fuel in the bowl - will not even start if I spray a little mix into the carb, not even with starting fluid ( I know bad idea) last resort
oldcatamount
It's got to be an ignition problem then. Points, coils, plugs. It could be that you have one bad coil but, You might as well do both.
Tim Frank
Check spark using a spark tester....the spark needs to jump at least a 5/16" gap.
fishon71
Spark looks good & strong on both plugs
oldcatamount
Have you tried a "link and synch" adjustment, where the throttle cam roller reachs the timing mark at the same time the carb butterfly begins to open?
D
DJ
Guest
75 psi is quite good.
Low speed about 1 1/2 turns out-as a starting point.
If your float is sinking (probably) you'll have to 1/2 choke it to get it going and stay running. Sounds backwards but is true.
The old cork floats had a habit of "sinking".
lindy46
If you have spark, and you spray pre-mixed fuel directly into the carb, it should at least fire for a second or two. Try again, and if you get nothing, take a look at the spark plugs and see if they are wet or dry. If dry, then fuel is not being drawn through the leaf plate.
steelespike
Are the coils new or have you checked the condition?Spark should be blue and have an audible snap.
Your flywheel key may be sheared.Just the slightest crease will throw off the spark.
You'll have spark but at the wrong time.Late.
Tim Frank
Looks can be deceiving...;)
How are you testing the spark?
That probably hurts. :rolleyes:
If you are using a proper spark tester, great.
If you are just grounding the plug to the block, good luck.
You can read all the reasons why this is an inadequate troubleshooting method in a multitude of posts in these forums.
fishon71
Okay pulled the flywheel and the coils are all dried out and cracked - most likely leaking. Now what is the pn for the coils and what year range will work. They look the same as stuff from the 80's
fishon71
I have a bunch of used coils that look like these but no numbers - is it safe to say if they look the same & fit they will work okay? They might be from late 70's motors and bigger hp's?
meyerboy
what is a "link and synch" adjustment?? is there an earlier post that explains this?..
Also, what do you mean by carb butterfly begins to open??? do you mean the reeds??
inquiring minds need to know.
