Pass on the Chrysler. The Merc looks to be about a 1970 or there abouts... Good motors when tuned correctly. If you are mechanically inclined you could fix it up.The guy selling this motor also had a early 80's Chrysler 20 hp. runs good, strong compression just needs a water pump.
Is that worth fixing?
Chrysler outboards have been out of production for nearly 20 years now. So you can image, parts are, and will continue to be tougher to come by. As supply dwindle, costs will go up. Although the Merc pictured is in ruff shape, parts are more numerous. good parts can be had on places like eBay or Craigslist. If you are willing to do the work yourself, costs can be kept to minimum. Also, a good running "red band" will have a higher re-sale value.Why pass on the Chrysler?
The cost to fix it?
Well if you already bought it why are you asking if it's worth fixing? What has to be "fixed" seeing that it MAYBE ran a decade go.Impeller/fuel pump/carbs and wiring will need to be addressed AFTER you check compression.That is the big question,report back with numbers on all 6 cylinders.Looks to be a short shaft and what are you putting it on? Serial number will tell you the year,what model is it?
Because I got it for free.
I was looking to buy a motor just to fix it up....that is why I posted about the Merc and the Chrysler.
I want to put the money into something that is high quality and unique.
i don't know what is a "top of the line" vintage outboard motor.
I am to new to boating, i don't know what is a "top of the line" vintage outboard motor.
If it was a muscle car I could relate...but it's new territory.
When you said you "picked up a motor" that usually means I bought one,not free.Anyway if you are looking for unique as stated a Merc Tower/Stacker/L6 are all in line 6, is a step in the right direction. A racing one is a much better find and that would include a 1500xs or Twister model,good luck in finding either one at a reasonable price.Your freebie is a early 60's,maybe 70-90 hp as it has a recoil pull start on the hat,not a rope inside.Nice engine and is missing the coverplate on the top of the midsection,not hard to find.IF you restore her and you want to put her on a boat I believe you need a boat with a 15" transom or you will have to put a jack plate$$ on a 20"transom to get it to work.If you would like to see some examples of the twister and 1500xs among other classic Mercs go to face book and search- in line 6 Mercury outboard motor fans- then click on the first picture you see.After that hit the forward arrow and scroll through the pics, you will see some of the nicest ones made.That site also has a lot of old time Merc guys that know them inside out.
I built a engine stand and got it sturdy.
I am trying to get a compression check done. The starter is spinning but not engaging the flywheel to turn the motor over.
So I will use the "pull start" to check the #'s. The problem is when I pull the rope the motor does not turn over.
Is it defective? Do I need to engage the pull start somehow to work?
