SnookHunter
- Joined
- Jul 19, 2006
- 29
I have a 16' lowe sea nymph aluminum boat with a 05 25hp yamaha 4 stroke with a aluminum michigan wheel 9 7/8 x 10 1/2.
Now with the setup just like that I could run 27.5mph by myself with a light load(gps verified) And 25mph with 2 people and a full load. I also didnt have a tack at the time, so no clue on the rpms. The av plate was also 2.5 inches below the bottom of the boat. I bought a Bobs machine mini manual jack plate and raised the motor so the AV plate is even with the bottom of the boat. And the setback is 5 inches. But now my top speed has decreased by a fair amount. I just purchased a tiny tach, so I could check the rpms. I can only reach 26.4mph by myself with a light load and the rpms reach 6140. With a 2 people and a full load i can only get 22.8mph at 6040rpms. I can raise the motor another inch if need be. What could be the problem? I thought raising the motor would mean less drag and a bit more speed. Is the prop causing the problem?
