Re: Is this safe for my engine (removal of primer connection)
The barb you removed was where the primer pulled fuel from the bottom of the carb bowl, then injected it into the engine. Putting a plug in place is perfectly fine. You will, however, not have the use of the primer. If you say you have never used it, you will never miss it.
