Today, my '95 Evinrude 60HP died after running on a plane. Couldn't for the life of me figure out why on the water. Got home and did a compression test. 105; 75; 110. Was worried, so I pulled the head. It looks like the top two cylinders are "dry." The bottom cylinder was oily and I could see the x-hatch hone pattern still on the cylinder wall. Now that I think back, the last few times I took her out, she seemed to plane a bit slow. My last carb rebuild was not last winter, but winter 2010. Inspecting the cylinder walls more closely, it looks the top and middle cylinders have a small amount of scoring (pictures attached). The bottom cylinder (picture also - the last one) looks good.
So, my question is, do I assume the top two carbs are gummed up, rebuild the carbs, seafoam the cylinders, and run/check compression and hope for the best - or does this scoring look significant enough to consider a rebuild? I've only rebuilt two outboards, so I'm not super confident in getting into a job of that proportion if I can bring this back to life. I put about 50 hours on her a year. Any advise from the gurus???
Thanks.
Thanks.
