Rranger
- Joined
- May 18, 2009
- 452
Is this engine worth the trouble of installing? Or is this the one I read all over to stay away from. Like all according to the seller it runs good. In a 1989 Apollo boat.
Is this engine worth the trouble of installing? Or is this the one I read all over to stay away from. Like all according to the seller it runs good. In a 1989 Apollo.
Yikes.470 blocks are aluminum and the head is cast iron from a Ford 460.
Are you swapping in a new engine or getting a new boat?So ideally probably the 4.3? What about older 6 cylinders or are there part issues for them to? The boat I have has a 4 cylinder 470 in it.
no I have a Reinell I want to repower the Apollo would be the donor boat.So you already bought the Apollo and now looking for best path. If the engine is good, install away. You will be learning all the gotchas with the 470 soon. Water pump seals, headgaskets, and so on.
then find a better donorno I have a Reinell I want to repower the Apollo would be the donor boat.
What he said!then find a better donor
Meh, don't listen to the haters. If the donor is in good shape I'd go with that. Yes, the 4.3 is a better engine probably. But the 3.7 is pretty damn good overall. The quirks are less important in a 30 year old engine. That donor already has the alternator. Can't tell the hx size; an 89 should have the 4". Last thing is the cam seals. Once the engine is out, it's no big deal to replace the seals and speedi sleeve the cam, and I'd do that before putting it back (iirc the oil pan gasket needs to be replaced for a proper repair). That repair will outlast the boat. I had my 3.7 for 12 years without an overheat, never had an issue with the cam seals or head gasket. I'm not looking forward to winterizing my 4.3, the 3.7 was literally a 45 second job.And the better donor would be what engine?
Says the guy who just finished a six month swap from a 3.7L to a 4.3L. heheMeh, don't listen to the haters.
Yeah, 6 month swap being the operative term. I've been completely unimpressed with the 4.3 so far in terms of everything except refinement. Definitely not worth the effort unless I can get some performance gains out of it. If it gets me up on a slalom then I'll be happy, but I'm not optimistic given the huge weight penalty. A 4.3 IS NOT plug and play. If you just want to go boating, stick with the 3.7.Says the guy who just finished a six month swap from a 3.7L to a 4.3L. hehe
since it appears that your existing boat does not have a motor, you would be better off with a V6 or V8 vs the 470And the better donor would be what engine?
