Is this the drain plug?
garzilla
Figured i'd start a new thread.....
Previous owner possibly put in a phillips head screw.....maybe.
jasper60103
Re: Is this the drain plug?
No, that's the pivot screw. Do not remove. It should be a slotted screw like I have below. Maybe it's under that crud, or below the bullet nose?
garzilla
Ahhh I see....yeah, I need to clean that friggin thing lol..
Manual shows it, but it's like from 15 feet away with a polaroid camera....thanks for the picture brother!
kbait
Asking that particular question, and waiting for an answer before removing that pivot bolt just saved you a headache and a half!
Nicely done 'zilla!! :)
garzilla
Ask first.....even if you look stupid....that's my motto lol
I should have cleaned the lower when i did the inside of the boat but too many old styles got me and I had to call it a day!
Today is my friday so carb cleaning, lower fluid, impeller, and might try to have her out saturday......after a thorough tank running first...then back to work sunday......
Btw, this place is better than the library lol.....thank god I have internet on my phone too!
boobie
You might be taking the bottom end of the G/C appart to get it back in properly. It's not old style, It's "old swill". LOL.
garzilla
Love me some old style....
eavega
Apparently chuck norris comes out and roundhouse kicks you between the eyes.....that's what the manual says at least.
You must have the Seloc manual. The OEM Manual says its Jack Bauer
:D:D:D:D
-E
kbait
If I wrote it, it'd be a Freddie Krueger/Hannibal Lecter combo!
garzilla
That screw is for the shifter pivot in all seriousness though right......bad news bears if removed..
Van Wildonher
Seriously, I think I removed that screw on one of my lower units, but I put it right back in because oil shot out. I don't want to break my engine when I go to run it now...
OptsyEagle
You won't break your engine. Worst case, it will not shift into gear anymore and you will need to completely dismantle the gearcase to repair it. If nothing moved and you put it right back in, chances are you will be OK. Just try to shift the gears to find out. Good luck.
jacksoldoutboards
It is not all that bad to remove it.. nothing really fall out that cannot be be relocated with a little shift handle movement. Not a big deal.. absent minded me have done it a couple times and I never had to remove the bottom end.
Just my two cents worth.... best to leave it in however and drain with the other plugs removed.
Mas
If the pivot was removed, the washer should be replaced since it was disrupted to prevent LU leaking at the very least.
Mas
