Is this the rectifier?
chimo
The black bar with the wires attached
ezeke
Re: Is this the rectifier?
The black bar is a wiring block. The triangular piece with the cylinder on the front of it (behind the wiring block in your photo) is the rectifier.
chimo
Thanks! When I'm testing the resistance of the rectifier wires I assume it's the ones in the photo??<br />I'll also assume the recifier isn't a "cheap" replacement part. :-(
ezeke
Just disconnect the three wires and then run the test. <br /><br />There are tons of used ones around, but new ones aren't that much either: web page
