is this video correct need ignition help
catfishcarl99
i have a 1980 115 v4. evin, i have no spark on the lower straboard side. i did these exact tests in this video. i have 550 ohms on port 545 on starboard on the 2 wire plugs he says is the trigger. the leads go to stator. CONFUSED! i had around 35 ohms on port and 65. like he did on the plug with 4 wires that run to trigger base. on starboard side where the spark issue is i had an open circuit showing bad. im thinking he said stator when he ment trigger and vs versa???
catfishcarl99
this is my readings from the 2 wire plugs he calls the trigger test. i can see they run to the stator. thats why im confused
catfishcarl99
now testing the big plug he said it stator but run to firing base (trigger) port and starboard have a tan with stripe, green, greenish, and a black with stripe.
first pic is port tan and green. 33 ohms. next is port tan and greenish 34 ohms. then green and greenish on port. 65 ohms. all in the normal range.
catfishcarl99
now starboard side 4 wire plug to the base (trigger). tan and green. infinate open. next is tan and greenish. 35 ohms. normal. the last is the green and greenish. infinate open. so whats bad lol. according to the video its the stator. but im thinking trigger since the wires that show open are running to it. correct my confusion please. thanks.
catfishcarl99
well i took both off. the video was obviously wrong. the trigger is bad. stator is reading good. already ordered new one.
