Is This WORTH REPAIRING , Imput please
evinrude 2.5
I have a 1988 2.5 Evinrude. I bought it for $40.00 bucks,not running and frozen up. I got it freed up thanks to some of you and it has helped me a lot. I got it running in a 30 gallon garbage can, but did'nt think to put on some kind of cover over the open part of the can. So when it started in a matter of seconds it blew half the water out of the can, so I shut it down with the kill switch. I refilled the can and tryed to start it again but it would'nt start. I checked for spark, both clys ok, I started smelling gas and saw it coming out the front of the bottom of the motor, so I stoped. Know I have it down in my small basement shop. I removed the covers and found fuel was leaking from the primer nipple that gos into the top of the carb. I also found a ring of fuel around the float bowl gasket. So I took it off and in doing so broke the plastic fuel shut off valve connection link that is a continuous part of the fuel shut off valve itself. I ordered the new shut off valve for around $7.00 and it will be in somtime next week. I felt I needed to tell the hole sad story to all of you who have had similiar problems. I called my motor every word in the book and even damed myself for not being more gentil with it , but none of the threats work. Now with it behind me I would like your imputs on weither I sould keep on going and make the repairs or just say **** ++ and save up for a new one. Are these little motors worth saving? and are they very reliable ? Thanks ,Dan Metz. :confused:
D
DJ
Guest
Re: Is This WORTH REPAIRING , Imput please
evinrude 2.5,<br /><br />Keep going. As long as the compression is good. Even if, and you should, replace the impeller, rebuild the carb. and replace the part that is broken, you're only going to have about 100 bucks in this thing-including purchase.
mrm
Keep going !!!! Hands on learning is the best.<br /><br /> Good luck and have fun<br /> MRM
