LilAnxious
- Joined
- Sep 5, 2009
- 7
Well the first water test run on the 72 Islander went well today. Boat didnt leak a bit. Not a bit of water taken on. Motor and drive both ran strong. Couple questions though.
1) Balance. Very little static weight load in the boat. Seats & old fuel tanks removed. The whole thing tilted when one of us moved. I am assuming once I add seats, hardware, fishing gear, and fifty gallons or so of fuel it will balance a lot better. Any input?
2) Thermostat. Water temp probably about fifty degrees. The thermostat never opened. Gauge warmed up to about the mid of the green and never past, but not sure how accurate this is. Gonna change it anyways this winter. Never got it to open either running on ears. Wondered if this was normal on ears or in cool water.
3) Little smoke out the oil breather at higher RPM's (4000). Nothing massive just a bit. Boat has been layed up for 7 years. Fresh oil and filter. Didnt know if this means I need to dig a little deeper in this motor, or maybe old build up.
I'll also ask the last two questions in the engine section. Any thoughts or advice appreciated.
