I did a quick search on Isolators but didn't finad anything related to my issue. Here goes...
I recently bought a 1988 21 Cruisers cuddy. It has a 5.7 350 Merc I/O. It has two deep cycle batteries. There is no selector switch. One is wired to the house and one to the starter. There was a Guest 2401 isolator on the boat that I replaced with a new Guest 2501 isolator because a terminal broke on the old one when I attempted to remove the wires to clean them up.
OK now the issue. I see a feed from the alternator to the isolator which makes sense. There are two more posts on the isolator intended to feed the charge to each battery. I see a wire leaving one of those posts to one of the + terminals on the battery which also makes sense. I do not see a wire leaving the other isolator terminal going to the other battery. What is connected to that other isolator post is an orange wire that I traced back to the engine wiring harness.
1. How can the other battery be charging if there isn't a wire feeding a charging current from the isolator to it?
2. What is the Orange wire coming from the wiring harness to the isolator stud that should be charging the other battery?
I tried my best to make that easy to follow. Any assistance would be greatly appreciated.
