Having an issue with my engine and kind of at a loss as to what it could be. Beginning of the season, replaced the fuel water separator filter and plugs like I do every year. Had some running issues after it was in the water so ended up rebuilding the carb. When putting carb back on, found the distributor was loose. Redid the timing per manual. Boat ran like a champ...better than it has in years. Had a spout of crappy weather and she sat for about 2-3 weeks....took boat out last week and it legit felt like we were running with a dead elephant in the back. Wouldn't get above 3300rpm or 19mph. Was swimming around it and noticed a crap ton of seaweed ont he outdrive and my trim tabs. Today, took it out and dove down and scraped all the crap off. Got her up to 4200 rpm and about 29mph which is pretty normal I think. Was a bit choppy and I had about half the weight capacity on the boat. Acceleration still sucks though. When I give it full throttle to take off...it feels like its bogging down...and you can hear it.....takes about 4-5 seconds and will get up to speed and seems fine after that. I rebuild the carb every year on this boat, and the only thing I did different this year was cut off the crappy guard over the mixture screw that doesn't allow you to take it out and replaced the screw. Figured it was 10 years old so time for a new one. Would that cause the issue? And if so...why was it running fine and now it's not? That's what is hanging me up.
Thanks!!
Thanks!!
