nathandarby67
- Joined
- May 28, 2009
- 13
Hey y'all. I am a long time reader here, but first time poster. First I'd like to say thanks to all the folks who have given so much good advice and never even knew I had taken it! This forum truly is a wealth of knowledge.
Background: I am a pretty mechanically inclined person, and do 99% of my own work on cars, houses, jet skis, weedeaters, toasters, and now a boat. Have restored a couple of cars from the ground up, etc. So even though I can fumble my way around a tool box ok, I know enough to know that I sure don't know everything, and that there is MUCH to be learned from both the real pros and the "seasoned amateurs". Thakfully this forum has plenty of both!
My rig: 2006 Volvo 3.0/SX-M (see picture of serial number plate if needed). Covered/trailered, on its 2rd season of use, maybe 50-75 hours total.
My issue: So last week we were boating peacefully along minding our own business and suddenly the automatic bilge kicked on. I knew something was bad wrong as the bilge has always stayed bone dry. Headed back in, and found the u-joint bellow had come loose from the transom side mount. I also noticed the gimbal bearing getting louder during the trip in and a slight vibration developing. I do not think it was leaking before this (no water in the bilge before), but it could certainly have had a slower leak going on for some time before the bellow came all the way off.
Pulled the outdrive yesterday in order to replace bellows, gimbal bearing and u-joints. I do not know if this had ever been done before we bought the boat so I figured I would do it all while I was in there. All is going well until I was using the 3-arm puller with a slide hammer. The first 8-10 "medium" strength whacks didn't budge it. On about the 3rd "really hard" whack one of the arms of the puller broke clean off at the hook and the puller came flying out and I go flying backwards to land on my butt. I get back up to find one side of the bearing has moved about 1/16 inch. This is where I left things.
Questions:
1) How worried should I be that I screwed up the gimbal housing by wedging the bearing a bit sideways? See the first picture.
2) What is the best way to proceed? Should I use a punch and try to drive the protruding edge of the bearing back square, and then go back to pulling?
3) I am replacing the u-joints as a precaution, but what should I do about the surface rust on the one side of the assembly? Any sort of special paint procedure like when painting the outdrive? (second picture)
4) What about the tiny pitting and scoring on the shaft on either side of where it interfaces with the gimbal bearing...should this cause concern? (third picture)
5)I haven't drained the outdrive oil yet (I am planning on changing it though), but pulled the dipstick and didn't see any signs of water. The upper gearbok input shaft seal "looks" ok, and there was no gear oil in the bellows. Should this part be ok? (fourth picture)
Sorry this is so long, but I wanted to provide all pertinent details and save everybody time on a lot of back-and-forth.
THANKS GUYS!
Nathan
Questions:
THANKS GUYS!
Nathan
