Issues with outdrive falling Slowly after raising it up!
Galaxytandy
I have a 88 Galaxy Works 350 OMC! Just had the lines replaced because it leaked oil in the system making me unable to raise up the outdrive at the launch ramp while ago. I had a local shop replace the lines with all of the O rings! When I raise the outdrive up parked in my driveway! Within about two hours the drive comes down! Other than that it rises up and down no problem! Any ideas?
kenny nunez
When the drive goes down stand on it to see if it goes all the way, if it seems to stop at a certain point when you stand on it one of the rams has an internal leak. If it goes all the way then either a line is leaking in the boat or the pump has a problem.
Galaxytandy
Thank you Kenny I'll try it this evening! I just had the lines on replaced! I see no leaks from anywhere! I'll double check thank you again
Galaxytandy
Bruceb58.
Looks like that did it! I ran it up and down several times last night Left it up, came out this morning and it's still in the same spot which is up! Thank you
