Our sailboat has a Johnson Seahorse outboard, and sometimes we have to use it... Only, now it's failing us.
It was running fine when we took a sharp lefthand turn, then it began to sputter and refused to run past idle. Revs up great in neutral, but put it gear and put a load on it, won't run at all quater twist past idle... Even then it won't hold a steady rev.
We replaced the plugs, and that cured the problem for a day. Now it's back to not wanting to run...
Considering this all began with a turn of the boat, I assume that the fuel tank sloshed and might've kicked up water or debris into the fuel line and into the motor. So, I've pulled the fuel tank and given it a thorough cleaning.
What else might be causing this problem? What can I do?
Any ideas are greatly appreciated, I'm at a loss...
Thanks -
Steve
Thanks -
Steve
