finally got my '79 rude 85hp rebuilt and after a new battery i got it to start YEAH!!! the only problem i encounter now is that after sitting for a while it is hard to get started again. after i prome the bulb, i have to crank it , choke it, crank it, turn off the choke, crank it, choke it, crank it, turn off the choke, and it will finally start and run like a champ. now i marked the choke linkage on the carbs and the choke solenoid before i took it apart so it should be pretty darn close to correct now but does this sound like a choke linkage adjustment problem? also ran the engine and read the voltage at the battery at 12.6vdc. is that a good way of checking to make sure the charging circuit is workin properly? thanks for everybody's help with my rebuild questions------the info i learned here is priceless.
