It's Battery Time!! 120hp Force Outboard
RadioWaves
Well, looks like both batteries are a bit weak so I'm going to swap them out. The previous owner had installed car batteries. yuk!<br /><br />I want to install marine dual-purpose batteries.<br /><br />What size battery should do I need for my 120hp Force outboard???
eurolarva
Re: It's Battery Time!! 120hp Force Outboard
I use a 575 cold crank deep cell battery. Can run the outboard and the trolling motor all day on one however I keep two. I get about 3 years per battery and swap out the oldest for the core. I keep the new battery for the outboard and use the older one for trolling. I paid 55 bucks for one today. If one goes bad it is nice to have a spare. If an emergency does come up there is an emergency pull on top of the flywheel and you should be able to start it with that.
