Hello, I've got an 3.0L OMC 4 cylinder 140HP. First, I'm not a mechanic nor am I familar with motors, which is why I've got this problem in the first place. Long story short, I knew this boat was not winterized but I got it anyways. I finally got the chance to mess with and and I checked all the fluids and put the muffs on it and tryed to start it. Water was rushing out of the exhaust manifold from a crack on the underside approx. 5" long.
I've been doing some reading on here and decided I would pull the manifold and attempt to repair it with some JB Weld. If that didn't work I was willng to purchase a new manifold for it. So, tonight I removed the manifold only to find another crack, this time on the engine block! This crack is also approx. 5" long and is right between two of the freeze plugs. The first freeze plug was popped but the second one was not. I did not see these freeze plugs and the crack because this area is usually covered by a panel containing I believe the solenoids for the trim/tilt.
So that is where I'm at and the only progress I've made thus far. I'm wondering what my options are now? Sell it for parts etc.? I'm a young guy with a small budget, so any work would have to be done by me. Remember I'm not a mechanic, but I'm willing to try to learn. So far the only thing I've learned is I should have walked away from this boat. LOL Any advice, opinions or instructions would be greatly appreciated.
