Slice of Life
- Joined
- Apr 2, 2013
- 78
Performing a visual inspection before taking the boat out into the slip for the first time this season, I look into my engine bay of my 92' Bayliner 2655 and see a line of ants on the starboard side going all the way to the back of the boat. I look to see where they are going, thinking it's a release hole that water goes through just under the engine bay door for when it rains, or something that's above the water line. Looking further I see there's a hole where a wire used to come through that's right under the starboard trim tab hose.
I look outside of the boat and then see the same line of ants coming out from the other end where the wires go in :facepalm:
I squirt a bit of water into the hole from inside the engine bay, and sure enough the water is leaking from outside where the wires go through near the hole that was made. A couple of seasons ago I put the boat into the water to find water gushing through around those trim tab hoses, where I guess the sealant wore off over time (or incorrect sealant used in the first place, just looks like black silicone)
Going to use some 3M 5200 both outside and inside in the engine bay, in and around the hole. Should I try to remove some of the old sealant/silicone first before applying the new stuff? Thanks.
