Re: Its melting!
I have the same problem with a 1975 50 hp Evinrude. I just bought the boat, runs OK but with less power than expected. The previous owner had installed a new battery, new plugs, new ignition coils, new wires, new and fuel pump. I found the tachometer was disconnected, so I reconnected it and it worked fine.
When I got home, I noticed a puddle of stuff coming from under the flywheel. This assembly has the green potted coils with the exception of the forward and aft coils, which are black.
I ran it on the mufflers, and it runs a little rough both at idle and 3k rpm. After I shut it off, I touched the forward coil and it was hot and soft.
I bought a new assembly (you can't replace just the charge coils on a 1975), but am hesitating to install it until I figure out what would cause this. I don't want to put the new one on and have it do the same thing.
Any suggestions on what might cause this?
