IV carb question
laurincole
Tried to start at the lake yesterday, nothing. Pulled the lid off and saw that the screws for the electric choke had backed out and upon removal of the carb, all 4 screws were loose. These 4 screws attach the bowl. Never had this problem before. Can I use a lock washer or some form of lock tite to keep this from happening again. Haven't tried to start enging since reinstalling. Would this be the reason for no start?
CATransplant
Re: IV carb question
Yup. Screw 'em back in and fire it up. I've never seen these screws back out, unless someone rebuilt the carb and didn't tighten them adequately. A fresh bowl gasket will spring a bit more and help lock the screws. If you use any form of loctite, make sure it's one with a low strength. You may want to remove those screws again someday.
laurincole
CA Transplant, What is adeqately. Is there a torque spec? I don't want to crack something. I have them screw driver tight. will try to start in a little while. Fortunatly my father brought his boat, so we will still have fun this week-end no matter what. Thanks
Paul Moir
Well, my books show 30 inch-lbs for #10 screws. Those don't need to be super-tight, I've never heard of them rattling loose. Just snug them up with a normal screwdriver pressure.
CATransplant
Paul's right. If you just use a screwdriver, tighten up until they feel "tight." It's hard to explain how something feels when it's tight enough...it's just a feeling you get from experience.<br /><br />Most tools that fit a fastener properly, have handles that are sized to give the proper torque with similar pressure. For example, a 7/16" combination wrench is shorter than a 5/8" combination wrench. To twist off or strip a 1/4" machine screw with a normal 7/16" wrench, you'd have to put abnormal pressure on the wrench. Normally, you just wouldn't do it.<br /><br />When I was a youngster, just starting out working on stuff, I broke a few things, but it didn't take long before I learned just how hard to lean on something to tighten it, and how hard to untwist a stuck fastener so as not to bust it.<br /><br />I guess you have to break off a few things before you learn. <br /><br />That said, if you use a normal-sized screwdriver to tighten those bowl screws and don't twist the heck out of 'em, you're unlikely to break them off.
