madgadget
- Joined
- Sep 28, 2009
- 281
This is a really long post.. Im sorry it probably wont interest many of you, but it actually solves IMO quite a mystery in the Mercury world of warning modules...
I have always suspected that the previous owner of my engine failed to maintain its effectively. I soon learnt that turning on the ignition and hearing no alarms was not normal and there should be some kind of alarm to indicate all was well.
So a few weeks ago I traced the wiring for the alarm (A small Piezo sounder in the engine controls) and I then grounded its supply and in theory it should then start beeping. It did - kind of intermittently, and then it started to stay on. So today I decided to look further and pull sounder out and test it on the bench. Normal operational range is 5-15 volts, so I gave it ago and sure enough it was playing up. No problem found another on ebay.
So on I went this time looking to see why when the should only be a short beep from the alarm the warning module on the engine was in fact putting out a continuous signal.
So I did some tests on this rather pricey module only to find that as suspected its defective.
So I then decided to do what any self respecting techno nut would do and then try and pull the unit apart without destroying it and try to establish the cause of failure.
Now this is harder than it seems in this case. Mercury have potted the module in a little plastic case with all the electronics covered in a hard setting rubber compound. The reason for this is quite simple. Its an attempt to keep out moisture and stop vibration from damaging the unit. Down side is chances of serviceability = almost none.
I did however make an amazing discovery... With a bit of careful prying and pushing I managed to pop out the potted electronics as a single lump without destroying it in the process.
I also immediately noticed something rather strange. There was signs of moisture in the bottom of the supposedly totally sealed case, in fact before this picture was taken, it was wet. Not only that I could see cracks along the potting compound where I could tell by looking closely the PCB sits, and now we have a way for the moisture to get in and quite possibly kill the module.. Now to see if its possible to see this..
I then carefully stuck a small (!) screwdriver just below where I could see the PCB end, I levered this slowly up and to my amazement the whole lot started to come away from the pcb revealing the entire face of the lower side.
This almost NEVER happens and only happened for me as the potting compound mercury use is quite flexible. Most are brittle like fibreglass resin, and so would never do this..
Check this out. I believe I've just solved the mystery why these modules fail so often for so many people:
Water damage anyone!?!!!
Reason is surprisingly simple. They sit on the outboard engine in the same orientation as the first image above. Water/moisture whatever sits in it and cant go anywhere. Give it enough time and it makes its way into the electronics. Had they been fitted to the engine the other way up I'm almost certain it would never have been a problem!
So now I have to decide what to do. I'm going to have a go at cleaning up the underside and will try to re-flow some of the connections but I'm 99% sure its beyond repair which leaves me with a bill for ?200 (Im in the UK) for a replacement or perhaps the alternative is to DIY my own module as a direct sit in replacement.. I suspect it could be done for ?20 and I probably have everything I need to do this anyway, just need to sit down and do it...
Not a bad afternoons work I think!!!
