jbuote
- Joined
- Aug 17, 2016
- 1,001
I'm making this post more to document for others what I'm finding as I go...
(However, please speak up if you feel I'm missing something or the plan could use adjustement..
The tilt stopped working our last trip out, engine was up and we had to troll back to ramp with electric trolling..
Backstory is here: https://forums.iboats.com/forum/eng...discussions/10584760-tilt-state-while-fishing
Symptoms experienced at the time are in the above link...
Since then, I've decided to leave it tilted down unless absolutely necessary to trim up..
Ours does not appear to be fused at the battery, but does run off the main 20AMP fuse inline off the solenoid.
Finally got out there yesterday to discover that main fuse was blown..
I now know that even if I had used the manual release (which I now know where it is and how to use it) the engine would not have started anyway... :faint:
Can't find the manual I ordered when I bought this boat/engine, so going to have to order another...
I hate working on this without the Factory Manual... At least for now there are numerous diagrams as well as the boatinfo site.. It also seems like a fairly straight forward issue, so I don't feel completely in the dark on this until the new manual comes in. (Famous last words right? haha! )
Plan of attack now, is to replace fuse, and go over (AGAIN..) every connection (Pos and Neg) to ensure clean shiny connections. Will also remove any components that are bolted to block for ground and clean that too.. (again...)
I will also use my multi-meter to check resistance between the ground lugs/studs to the block.. I had that issue on my '71 50 hp a while back..
I will also examine wiring harness for any wires with broken insulation..
We've use this engine/boat combo a few times now but this is the first time it blew a fuse.. It also happened to be the first time it was tilted this far up... Will also be looking at the limit switch to prevent over-tilting.. Not sure that was working..
Other than this tilt issue, I've had ZERO complaints with this engine.. It has been a dream so far! Love it!!
Again, if anyone has thoughts I have not considered here, please feel free to let me know!
I will update as I get time to work on it and post how the results of each step go, along with any other issues found besides a blown fuse,...
