J150 controls
jonesg
Trying to hook up the wiring harness on my 150 (1994), a couple of problems, how many buzzers are there supposed to be? the one that came on my (used) harness was broken but there was a loose one in the box so I swapped that in, it chirps when the ignition is first energized.
I don't have the fuel tank hooked up yet, nor the VRO tank wiring....so I haven't run it yet.
Does the VRO have its own seperate buzzer ?
Also missing is the kill switch, I've identified the wiring at the controler end of the harness but it was cut off when removed from wherever it came from. Is this something common I can pick up local, I've seen lanyards but not the actual switch.
ezeke
Re: J150 controls
The VRO uses the same horn as the overheat warning all are connected through the main harness via a tan wire.
Print the article at the following thread, the wiring diagram will help: http://continuouswave.com/whaler/reference/ignitionSwitch.html
Find your remote control at the following link by selecting "OB Accessories" at the pick list and navigating to your specific remote control. The parts diagram will list the correct kill switch and lanyard numbers for your setup: http://shop2.evinrude.com/
