reiddo1
- Joined
- Jan 17, 2012
- 166
I recently bought a used 1996 200 hp Evinrude lower unit from a E200txedr and was hoping it would be a direct swap with my 2000 Johnson 150 hp counter rotating. I am trying to make a change since prop selection for the counter rotating is limited. All looks the same except the shift rod and drive shaft on the Evinrude which each are approximately one inch longer than the counter rotating Johnson. The parts diagrams in each case show a two piece drive shaft. My question is can I swap the Upper drive shafts and shift rods easily?
