J185TLCOC vacuum switch? what is this?
cliffmccue
Hey Guys,
I'm a Noob so bear with me.What does the Vacuum switch do on a 1985 185 hp johnson?It connects to the fuel line at a Tee in the line after the filter before the pump.Any ideas?
Joe Reeves
Re: J185TLCOC vacuum switch? what is this?
Should you encounter a fuel restriction between the fuel pump and the fuel supply, a vacuum will be created at that switch which will cause the warning horn to sound constantly..... the same warning as you would encounter if the engine overheated.
cliffmccue
thanks,just trying to sort out what is what,learning more everyday
