bart98stang
- Joined
- Mar 6, 2011
- 104
Hello, I have a '91 Johnson 200 J200STLEI I just procured. The steering cable does not go through the tilt tube and after talking with the previous owner and searching around I found that the cable can be bolted up to the yoke and then clamped to a bracket mounted to the transom. I've added a couple of pictures but the angle to take them was kind of crappy.
The first question I have is is this a "normal" set up and will it be ok for usage? I understand that many outboards have the steering cable go through the tilt tube.
Second question is is there a set up I can buy to have the cable go through the tilt tube then bolt up to a linkage and then up to the yoke?
