ChrisinNashville
- Joined
- Nov 13, 2014
- 21
Hi all,
Need a little help please. 1988 J40ECCS, been sitting for about 3 years. Fresh carb rebuild, new plugs, wires appear fine.
VRO has been removed, so pre mixing with a standard fuel pump.
If I remove the coil wire from the top cylinder the popping stops. Tried swapping the coils and it stays with the top cylinder.
Trying to narrow it down to a fuel or ignition problem, have a look. https://youtu.be/NK2KTOKzc7E
I'm suspecting the power pack...
Any thoughts appreciated,
Thank you
Thank you
