The lower unit was leaking and the oil was milky.
I took the lower unit apart, where the shaft goes into the lower unit it looks like there was suppose to be a seal?
There was rubber pieces there. There are about six-eight hole on the side of the lower unit just under the fin/lip.
What is suppose to go there?
Where can I get it?
Also: Are there suppose to be gaskets/seals under the mating parts?
IE...
Lower unit to shaft?
Bracket that holds shaft in place over where I found the rubber pieces?
I hope this makes since....Please Help I have a boat with no motor now= No FISHING!
Where can I get it?
IE...
