Jabsco Electric head conversion
mr 88
I did but was not aware of that set up. I just bought a macerator pump and plumed it in under the sink where it can be accessed and not seen. Left everything else in place,pump in raw water ,hit rocker switch and it's pretty much all gone. It takes almost everything out,100% better than the pump that left a lot more in the bowl and didn't shred the paper like the pump does. spent about 115.000 for pump and switch. I am happy with the "end product "...
shaw520
Interesting idea,.. My macerater pump is still wired and in place,.. But the overboard plumbing has been disconnected. Wonder if i can just use it and plumb it to the holding tank.
mr 88
I would try that before dropping any money and a bit of time into what your link shows. All I needed was a reducer for the hose going to the tank as the outlet from the pump was smaller than the that hose,once it s macerated you don't need the 1" 1/2 line, but I kept it after the reducer,easier and cheaper than putting a new hose the whole length.
